Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
Ok then, following on from a thread the other day...
I have now fitted my cupra R holder and it looks mint...
Im now after gauges that look pretty damn identical and fit well with the clocks......
Apparnatly these are one of the best and glow the same too without bulb changing?
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3514
anyone recommend? or others???
and also preferably fit in the cupra r holder without having to damage any dash behind it......although if it has to come down to it il have to cut part of it....
anyone got pics of theres in this position (don't want no mad pillar pods please) and what gauges they are using...
Looks like i will want a BOOST GAUGE and a OIL TEMP GAUGE as these are the easiest to fit...
Thanks for help in advance...
Rich
mine is in a nomad racing pillar, so no good for you
but yes they match the dash, can also get some more 'redder' coloured ends to go over the bulbs too
just found a picture...
nice actually ultra lite or ultra lite 2??
Very nice..... whereabouts can you get them and as per questions above, did you have to modify dash to fit?
thanks dude, im after someone who used the cupra r holder and hasn't cut the dash.....
cracking stuff......
where do most people buy there gauges? if autometer ones etc?
I brought my gauges from a dude from here cheap cheap, but im needing to get a 30psi boost gauge soon and ive seen a good few on ebay, There is a phantom 2 you could take a look at they look pretty well. Would be the first on here to have them aswell i think.
David.
I did manage to find a 30psi on there, im seriously considering replacing my phantoms with the phantom 2`s. As i think they look alot better.
David.
Im sure i see a oil temp aswell for the phantom 2`s?
Im pretty sure all you have to do is tap in to the oil filter housing using the blanking plug at the top for the oil pressure, Unless yours is seized in like mine and i ended up rounding it :(, You maybe be able to run the pressure sender from the sump plug with the correct adapter but im not sure.
David.
