I have to wonder, is it the job of Cupra Digital Support to blame everything else except Cupra for issues?
1. Reporting issues with charging via Octopus Intelligent Go, point them to a bunch of places online with people who have the same issue. Nothing but pointing the finger at Octopus and/or MyEngergi (Zappi). Ignore the fact every other we've used the charger/IOG with works fine, it's always the Born that times out and refuses charge, massive threads on the Zappi/Cupra/Reddit forums with lots of people on the ID3 (and other VAG platforms) with exactly the same issues.
2. Issue with the screen on the infotainment going blank occasionally after an OTA update. Must be "environmental factors" and case closed. Asked if they at least add it to a software issues register for any devs to look at, no reply.
3. Issue with scheduled charging blowing past the preferred times set, leading to charging at peak rates (because I can't use smart charging...), again reassured that the car will only charge during the times set, but will go past that again due to "environmental factors" such as the BMS in the car. Case closed.
It just seems like they're trained to blame everything else and refuse to admit there's any sort of issue with the car? Anyone else experience the same thing using their non-dealer support channels?
