cupra tdi, white smoke and service
mercieca
HI Guys,
Just noticed that my cupra tdi is smoking a little when i start up in the morning, white smoke to be exact. is that a worry. Its due its two year service should i try and get it done asap. they are quoting me £361.21 for a 2 year service and brake fluid change. can it wait till my hols are done
cheers
mercieca
whats the damage for a new turbo, i hope my cargiant warrenty pays out on that
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
same happened to me turned out seat had put my cambelt on wrong went bigger turbo and never regretted it :D
Oct 12, 2005
1,013
That white smoke on startup is perfectly normal. As long as it goes away and after a few seconds and then you get black smoke if any at all then its ok.
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
are you getting confused with white smoke and steam ?
steam is perfectly normal on damp mornings, like when you can see your breath
the engine compresses the air from the atmosphere and when it exits the tailpipe it is hot and the exhaust that it has traveled through along with the air outside is cold, this makes steam
white smoke is another story altogether
