Dab aerial for an RNS 315?
Nov 10, 2004
1,000
Colchester, Essex
Hey folks, fitted my RNS 315 today (swapped from a 310) and didn't realise I do not have a factory DAB aerial! And so I was wondering,
I need to get a DAB aerial that will plug into the black port on the rear of the 315, I was looking at this;
http://www.halfords.com/webapp/wcs/...uctId_891553_langId_-1_categoryId_265868#tab1
Is that the right sorta thing?
And another question, is it going to be a pain to fit? I'd like minimal effort on this one! Was thinking about putting it lower front windscreen and dropping the wire down the heater vent into the rear of the RNS?
Nov 10, 2004
1,000
Colchester, Essex
Also I noticed it says Bluetooth streaming altho it doesn't work? Yet I do get the full dialling interface etc
Do I need to disable the factory Bluetooth and enable the rns315 Bluetooth only? (If that's even possible!)
fireblade929
152
Cleethorpes
You can get the aerial on eBay, it also has a blue connector that plugs in the back of the rns315. The other end is square ish in shape and has a sticky pad on it, this can be stuck on the cross beam behind the dash and will have no problems picking up a signal.
