Just got In from picking up my AUM 20vt Full Bottom End..
Has only covered 36k miles and it looks in mint condition tbh.I Opted not to get the sump as im gonna get a Jabbasport baffled sump IRRC Anyway Tomorrows Jobs is to strip it all down and Clean and & paint it up..
Some Pics:
no going back now mate
so do you actually know what you are doing, in terms of rods, valves etc? fair play thought as I dont have a clue on how to do engine internals
so what is actually on the shopping list now that you have the block?
Yeah i have a Fair Idea Mate Which is a start I suppose and plus ive got loads of help more than id thought id get...
I just need to get all the torque setting for every bolts to make sure its done right..
Shopping List is:
82.5mm Wossner Piston
Scatt Rod with 19mm Pin
All New gaskets
New Big end Bearings
New Timing chain
Bored and Linished Block
BDM Baffled Sump
I haven't thought about the Head as yet....Wanna get the Bottom end done 1st
Shopping List is:
All New gaskets
New Timing chain
BDM Baffled Sump
nice
makes me think twice about going hybrid k03s....
but no seriously, the spending has to stop now, this is the last big job
best of luck with the build...I suspect another 100+ more pages of build thread info:D
Had a Early start today so needed to get a move on with the shed...As it was a disgrace..
The Shed:
Then Was time to pull it all out and Sort it all out (Big Thanks To me MUM )
All Clear :D Ready for my Mess
I sorted ZZZZ Tunes OWt:D
The Supplies :d
next Job for me is to Degrees and Tidy Up the block:
Once it was all clean,Ready for some Paint While i was at it i painted my Spare Alternator which came up really well tbh:
Just waiting on my Engine Stand & Female E Torx bits so i can get to work :D
Why 82.5mm and why 19mm wrist pin rods?
Do Scat even do 19mm rods? Im sure they only do 20mm.
What you mean your gonna replace the timing chain in the block?
I Have been told that 82.5mm Is to make it a 1.9 which ive desided not to isnt really worth it...
Im looking at getting some S3 Piston If i can get them for a decent price as there 20mm Pins aint they
Im sure i read that scat were 19mm Pins But might have read it wrong...
RightyO the list i have so far is:
INA Connecting rods (19mm wrist Pins)
New Crank shaft Shells
New HeadGasket
New Rocker Gasket
New Spark Plug gasket
New Throttle bodie gasket
New Oil sump Gasket
New Piston rings(seals)
New Oil Filter
New Oil Pump
New Oil retainer
New Water Pump
New Timing Belt & Alternator Belt
New Timing Belt Tensioner
New oil return pipe line gasket,
New Oil and coolant union washers
New Inlet Manifold Gasket (Phenolic One)
New Ik22 spark plugs
New Water Pump (Metal Impeller)
Red Torco Engine assemble Grease
I miss anything off for the engine?
Ive Been Offered this Fully Built cylinder head and Rocker cover £50 has covered 111k miles what you reckon pics:
What would i have to change to get it back to new ...
Ive Desided today that Im going to Fully strip the Ibiza...
Im gonna make it in to a Fun track/Weekend Toy for me only...So goin looking at a 1.9TDI golf and a Black 3 door astra Sxi on saturday..
So i can use it as a Noraml Daily car and just leave it for the dutys and have the cupra for my beast :D
