Daz powder - Suggestions
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
This is the weird thing ever! i dont know were its coming from!
On the battery on the postive termianl. im getting a white/dotted substance like washing up powder!
It came up 2months ago! ive cleaned it and it came again, cleaned it it came again!
And again!
Whats is this? Dont think its a good thing :(
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Could be dried battery acid which has caused corrosion, which could be a sign that your battery is leaking. If this is it, I think you need a new battery!
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
Sounds like semi-normal build up you get on the terminals...easiest thing to do (if your battery isn't acting like it's too tired) is to take the terminals off, clean up said Daz ;) (from both terminals & clamps) grease the terminals on the battery & re-connect.
Should save you the £60+ for a new battery if it's not the battery that's actually at fault.
Big_daddy
Oct 20, 2006
3,930
Brummy
Ive done once or twice (when fitting the new typhoon filter).
ive cleaned it fully! and greased the terminals with copper grease!
cmc
ohhhhh yes.
Sep 13, 2002
637
Glasgow
Is it a green/ white like colour? If so definitely battery corrosion. Will clean up with water but you may be too late. I had this about 2 months ago. Caused by battery arcing due to the connection not being tight enough to the battery.
I only noticed it when my car failed to start one day! Needed a new battery in the end and a new negative terminal lead harness in my case as even with the new battery the corrosion was coming back. The new negative terminal lead was a real pain in the @rse to fit I tell you.
If I were you i'd unscrew your battery. Give the terminal ends on the harness lead leads a good clean with a wire brush. Clean your battery terminals with a wire brush and screw the leads back on nice and tight and cover generously with Vaseline or copper grease as said above.
Check again in a few weeks to see if it returns, you might have caught it in time.
cmc
Big_daddy
Oct 20, 2006
3,930
Brummy
Well its mainly a white susbstance! with dotted blue things!
[/IMG]
[/IMG]
The battery indicator is green
[/IMG]
Steve221
Workshy Fop.
May 30, 2003
562
Newcastle
standard reaction, i'm a maintenance engineer and see that all the time. you just need to give it another full clean, re-fit the terminals then cover with vaseline or an aerosol of proper battery terminal protector ensuring you haven't missed any spots. The most likely damage to be caused by leaving it is it will slowly eat away your terminals, then you will start to get starting/charging problems.
Big_daddy
Oct 20, 2006
3,930
Brummy
Just had a new battery fitted, any suggestion on what to use to clean the terminals?
gave it a quick sand 2weeks ago with some copper grease and the corrsion is back again [:@]
marshyc
299
Huddersfield
I wouldn't use copper grease as it will be very conductive and will probably add to any arcing or corrosion that is happening. As suggested use some vaseline, battery terminal protector or just some all purpose grease which you can get big tubs of at most decent car places.
