diesel particulate filter problems
Bruce1
There are lots of us out there and I'm sure you will get backing from many on this Forum. You can count me in!!
Lukeyx
Rootmonkey
Nov 30, 2008
219
Grimsby
I had my FR170 for 4 weeks, then swapped it for the FR DSG Petrol (And lost £3k). DPF so annoying, people should start ringing watchdog lol.
AndrewJB
Friend to SEAT UK & Cupra Racing
Aug 16, 2007
11,175
485
Maranello
Unfortunately its not just SEAT
All of the VAG Range that offer Diesels ( Skoda,SEAT,VW and Audi) have had the same problems with the PD170, WHY?
Because the PD Engines wernt designed to have the DPF Fitted, This is why VAG has now started using the CR Engines as they where designed to have DPF Fitted
betty_swollox
Richie
Feb 15, 2011
5,497
7
Washington
A lad I work with reckon VAG were tight and didn't use the CR injection earlier when they should of. is that right or is the little gimp talking crap??
AndrewJB
Aug 16, 2007
11,175
485
Maranello
CR Engines have been around for a fair few years now mum and dad have a CR Powered Laguna on an 03 plate , it seems VAG didnt want to use CR and they decided to around 2007ish
GrahamFR
Now AMG Powered
Dec 10, 2008
4,235
Barnsley or Burton
i imagine he's talking crap, i heard the PD's were a much more complicated system compared to the Common Rail thats probably why the dpf's dont work on them. The way i see it was that the VAG were being clever with their PD's (cos lets face it if you were going to buy a diesel from the sort of year 2000range you wouldnt buy anything other than VAG as the rest were a bit poor) but when the new regs came in they just havent been able to make the two work in conjunction.
Justa
261
Derby
this is what a VAG specialist told me - the DPF was added on to the PD engine and it just doesn't work...
This is making me feel better about only getting 30 mpg from my petrol FR - I wanted diesel but the DPF issues I had with my last car (Alfa 159) put me off...
Fusster
148
where do I go from here?
I would hope they are taking it for extended test drives and they should be checking the readings of the 3 temp sensors as these will also stop regen if reading incorectly.there have also been 2-3 software updates to improve regen,hopefully they have checked the software version.
If it has gone in to limp with them using it that would suggest a underlying issue.
I have also had a couple of leons that were blocking the particle filter due to the incorrect oil(not long life)
Just because there is no specific fault stored does not mean there is no problem although i would say i have also had customers that had repeat dpf issues that i ran the car for a week (500miles) with no issues and several regenerations (you can check to see if the vehicle has regenerated automatically).
But all avenues were exhausted before we were happy to say the car was fault free.
hope you have some success with them.
Alzak
666
how i can check if my sensors works as they should as my car go into regen every 90 miles even if ~I come down from Motorway it sometimes go in regen mode ??
Bruce1
Alzak, sounds like your sensor is working if it's trying to regen. How often are you seeing the DPF light coming up on the dash? Does it clear after a 10-15 minute run on the motorway?
Alzak
666
I do not see light often is just first and second stage of regeneration and is real pain in a..ss this is every 90-100 miles
/dev/null
1,652
101
I do around 500 motorway miles a week in mine and still get the regeneration happening which makes the car feel like complete crap, no power below 2.5k revs then extremely jerky after that. Never see a warning light though.
Cuprarob112
403
Guess I wouldn't since the 2.0 Hdi in my peugeot is from 2000 still does approx. 140 bhp (tuned) without going fault for even once for over 140.000 miles. Thing is the French did manage to produce good diesels in the past but electronics aren't their strongest point. Nowadays you can still find french diesels in all kinds of cars but instead of more reliable than the 2.0 the newer 1.6 is a pain in the ......
m4rtin
388
Northwich, Cheshire
I was planning to get a Leon FR TDi CR in around 6 months but this thread has put me off a bit. :-(
I'm I correct in thinking the DPF issues are mainly with the PD engines?
Has anyone with a CR engine had any problems?
My drive to work is approx 20 miles and is a mixture of A Roads and Motorway (around 10 mins on Motorway).
Bruce1
Dev, I have the same problem but I don't think it's DPF related. My DPF is now clean and I still have that fault. I am currently checking a few things out and will let you know once I solve it.
AndrewJB
Aug 16, 2007
11,175
485
Maranello
CR is alot better, casnt guarantee it wont have problems but they dont seem to
