I'm getting this fault code come up,along with the esp light on the dash:-
Control Module Part Number: 06A 906 032 MJ
Component and/or Version: 1.8L R4/5VT 0003
Software Coding: 11510
Work Shop Code: WSC 66565
Additional Info: VSSZZZ1MZ3R126658 SEZ7Z0C2005673
1 Fault Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Dealer says its the BF exhaust messing with the lambda settings
,anyhow spoke to Will at P-Torque and this can be mapped out when i go stage 2.Question is,why after i reset the fault code,does it not appear straight away?I'd have thought once engine was running,sensors would spot the problem?
i've just done near 400 miles,no code,then the light came on as i was sitting with the car idling(incidentally,this is when the light seems to come on the most)???
Can any of you in the know,explain why this happens please,and if it does require mapped out or just to keep clearing the fault code?
Cowie
1 Fault Found:
P0420 - 35-00 - -
,anyhow spoke to Will at P-Torque and this can be mapped out when i go stage 2.Question is,why after i reset the fault code,does it not appear straight away?I'd have thought once engine was running,sensors would spot the problem?i've just done near 400 miles,no code,then the light came on as i was sitting with the car idling(incidentally,this is when the light seems to come on the most)???
Cowie
