It's the DQ200 what the fuss was about. They swapped to synthetic oil then went back to mineral oil which fixed it.
Now they wouldn't fit that to a Cupra since it wouldn't be strong enough for the engines on Cupra
Ateca's. According to Honest John ex Telegraph its safe on a 1 litre but anything above and there are issues. Think you find it on 1.5 litre normal Atecas and people on boards wanting to chip their engines for more power. Truly stupid on that gear box. You would get rumbled when the gear box broke.
The DQ200 is on our little Arona with a 1 litre, 3 cylinder engine, no problems. DQ381 on the 2 litre diesel which is wet.
If you are buying one second hand or want to know the components parts in the car (build codes) a useful trick is to photograph the VIN on the windscreen. Spend £8 on Erwin. Link on the
Ateca standard thread on
how to do it. Download the VIN lookup. The
workshop manuals are there plus the
dealer training material (SSPs). You might need more than an hours time. Depends how quick you are. Two will do. You get all the technical material.
Also a discussion here with a table of the gear boxes.
Answer (1 of 5): Hey. Thanks for the A2A. :) The 7 speed DSG is used in the following combinations. Now. The problematic gearbox was the DQ200 one. Which does duty in the VW Polo GT TSI, Vento TSI, Skoda Ovtavia TSI, Skoda Superb TSI as of now. There's two issues with them. 1. Mechatronic Fai...
www.quora.com
A Google on DQ200 turns stuff up like this:
The dry clutch 7 speed DSG gearbox suffers from several common faults. This
guide details the issues that affect the Audi S Tronic, VW, Seat and Skoda, DSG 7 speed models which can be repaired and even upgraded with modified parts. Please note, this
guide is for the DSG 7 Dry Clutch systems...
www.eco-torque.co.uk
Basically 1 litre on the DQ200 you are fine. Anything above 1 litre to 2 beware probably a DQ200 fitted. Above 2 litres they don't fit them.
I did pick up Honest John when he was rubbishing them on Seats once, I pointed out it didn't tally with what he'd previously said about 1 litre and DQ200 being fine. He agreed ?. He said in an email to me that he still gets complaints above 1 litre with the DQ200 fitted but not on 1 litre ones. Cupra big engines will be fine ?.
