iadam03
Greater Manchester
Hello all!
I have a Seat leon mk3 190 DSG and I came across an emergency mode fault. Car only went into even gears.
Long story short, I have the car at a VAG specialist garage and they've come back to me that the mechatronics unit would need replacing. They've ordered the replacement unit from Germany. They said 2 weeks but wasn't too sure if this was the case. I understand that the unit will need programming.
Has anyone recently ordered a mechatronics unit from Germany and if so how long it took to arrive?
They did advise that the work would take 3-4 hours once it arrives.
Thank you
Was the fault code relating to that clutch 2 opens unintentionally?
From experience, it's the control unit on the mechatronics module that needs replacing, that's a special order part tailored to your vehicle and takes 7-10 days to arrive.
However, the complete mechatronics modules can be fitted to any applicable vehicle. If they're not on backorder they usually arrive within a couple of days, there is a significant price difference between the two repair methods.
Glad it all got sorted under warranty, that's a big old bill otherwise. How many miles was your car on when it failed?
I never drive my diesel in S but then you wouldn't ;). Gone are the old day of DSGs and no SCR when annoying people behind you, you could cover in diesel particles. Now jab your foot down, no smoke but they do go.
Apart from normal mechanical failure with second hand cars, you don't know what level of abuse the gearbox has been given... that's if it's second hand. Those people that chip their engines, the gear box is designed to take the torque matched to it, but not with with a chipped engine. May be yours isn't second hand but if so you don't know what the previous owner got up to with it and those videos of what you dont do with DSGs. The costs involved if they go wrong.
