This has been going on for a while now and I'm going to try explain best I can.
Ok what happens is at high revs on bumpy roads, when I am over 4k rpm the engine noise is slightly louder than it should it and sounds a little 'rough' but the engine is fine, there is also when going over these bumps vibration which i can only describe as being a high speed vibration of two solid parts that are only slightly loose. It only happens just as you go over the bump.
The noise sounds like its coming from the drivers side footwell area.
any suggestions, it has had cambelt and the drivers side cv joint changed in the past couple of months if that might make a difference.
