dump valve and engine light problem
tripper
58
birmigham
hello to everyone just joined this site as i`ve just brought an 03 seat leon cupra hope somone can help me the car has an induction kit fitted and a dump valve but ecu light is on i`ve been told by the guy its cos of the dump valve being changed he has also given me the original one can someone tell me if this is correct and can it be reset or will i have to change it back.
NeilW
Platinum Member
Jul 6, 2004
322
Yorkshire!!!
Change it back. The light is probably the least of your worries if you keep it on. Or get a Forge 007 instead. Plenty of info available if you search.
tripper
58
birmigham
after reading that i think i`ll change it to the forge type. does the original valve make any noise or do the forge ones
NeilW
Platinum Member
Jul 6, 2004
322
Yorkshire!!!
Neither make any noise worth speaking of. The Forge is better made (metal vs plastic) and will last longer. Some people say they get better throttle response etc.
WeeJase
pert
Jun 2, 2001
8,595
what induction kit is on it mate?if they have put an atmos dump valve on the car ,god knows what they are using to filter the air.
