funkymunky1983
can some one please give me some advise on fitting a dump valve on my seat leon cupra r
can i replace the plastic standard with a uprated piston dump valve with out the fitting kit
i want tto replace the plastic dump valve and put a loud one on with out using a fitting kit is it possible
:doh: You have to be joking?
Now where's that plug in for VB that makes you search before it'll let you create a new thread?
Tssssccchhhh Tsssssccchhhh is the noise jap crap makes :p
Leon is far to classy for that. You can't have a tssscchhhh wooshy DV noise on the 1.8T with anything other than the new Forge Split R.
u know the plastic bosch standard dump valve u dnt need a fitting kit 4 that can i swap the plastic dump valve with a forge one with out out usig a fitting kit and i dnt mean a re-circulating one
No txt speak here!
sorry you lost me at fitting kit but since theres no punctuation in your posts its very difficult to understand a word youre saying so yes you can fit a forge 007p which will need some new jubilee clips to replace the standard hose clips as theyre once only clips and cant be reused and you can fit a forge splitr valve that will give you that whooshy feeling and youll need the jubilee clips again if you count replacement jubilee clips as a fitting kit then no you cant fit any valve without a fitting kit but otherwise i have no idea what you are talking about a fitting kit if youd search then you would already know the answer to these questions without this useless thread where everyone will now take the micheal out of you for your non use of the queens english so in future please use the search function of the forum found on the top menu bar although you will have to use non text speak in the search otherwise it will find jack
( Few that was so difficult to type without any punctuation or capitalisation... :lol: )
:clap:
