Look on the last few pages someone has a whole load of pics.. it so much easir than the first post makes it out to be..
it just a cast of searching through the last 3 pages or so, if you get really stuck, i'll post a few pics for you..
that bird is my Girlfriend mate haha! cheers for that.
which my car was as fantastic.done the bypass and its still dumping on its own and now the management light has come on!
this car is doing my F*cking head in!!!!
wat valve u got oan u should really only use a forge 007 oan thses cars
lol, dump valves dont to anything, the standard one is more than enough for what we need..
Try looking for boost leaks, or failing that the N75 valve.. which are coomon places to try and troubleshoot boost issues..
Or contact the people who did your remap...
going to check the boost pipes for leaks after, what is the n75 valve?
what about the maf could it be that thatis gone or would i jus have a consistent problem with that and not just a intermittent boost problem.
its a APR dump valve by the way.
lights on dash means that theirs codes available to scan
you got vagcom or know anyone local? would tell you straight away what the problem is :)
the light has gone off now.i plugged the small part of the n249 back in and the light went off. i think there must be a leak in th eboost pipes somewhere jsut finding it is proving difficult.
small part of the N249??
you got any pics of what you have done? not convinced its correct
the code will still be their if you plug vagcom in until you clear it, id try and find someone local with it and ask if they can scan your car for a few beer tokens
sounds like ant done somethng right
