cupra drew
full leather of course
May 28, 2008
273
cheshire/winsford
changed one bout a month ago and ive just started geting the same symptoms again unplugged them lastnite and they all woked fine but will this method work if one has only just started to go should i drive it more to see if the coilpack gets worse then unplug again when one mite b totally knackerd to b sure any help please
indeed. test won't work. Plus vagcom will also most probably not pick it up. Will have to wait...or change them all (which I wouldn;t do due to costs.)
i got my 4 coilpacks for £72 all in, intermotor ones from a motor factor i used to work at, mind u that was with my discount but even retail on them was £21 a piece so £84 they wuda been to anybody else, i had one coilpack go, then changed it, and on the same day i was doing a high speed run and one of the others went so i changed them all
nut im talking original genuine vw parts
if you want to get them from tps it will depend on the guy serving you as we only supposed to deal with the trade. so be wary who you speak to but if youre in s wales area come to cardiff tps and ask for craig or greg we are both on here and both own cupras so we will sort you out.
