JKing
Cupra-R
Aug 9, 2003
598
Mansfield, Notts
photobucket.com
Ok I've got a new Electric window motor for the drivers side to fit. Taking the old one out to check it was broke was a nightmare. The cables which control the window kept coming unravelled from the spool on the motor. Any tips to make this job easier??
yea did mate bit the bullet and did it.yea nearly there only got the "ripspeed" alloys to come of.standard alloys are away getting sprayed black.coilovers are ordered should be here next week.forge fmic fitted what a git to fit did it myself.fininished night shift of the friday morning and spent all day fitting it fell asleep under the car.are you going to crail on the 24th im ment to be but tore ligaments in my ancle last night so wait and see really want to go.
good stuff!! falling asleep under the car, u r proper hardcore!!! yeah i'll be at crail that weekend as long as i can get my mods finished in time!!
With the whole regulator and motor unit still as one, remove the 3 screws on the old metal motor case and then slide it off. You can then wind the motor by hand to tension up the cables again and send the window carriers to the highest point. Mine did not unravell after this. Good luck
