Right, bit of an odd one for me. Sorry in advance, I'm going to bang on a bit like a dumber version of James May, in that I will likely just bore the hell out of you rather than also showing off technical talent.
Recently I've had some electrical gremlins affecting all the exterior lights.
When depressing the brake pedal, both side's indicators come on constant (front and back) rather than flashing and dipped beams come on, as well as brake lights.
With brake pedal depressed and indicators on, the indicator's flashing is quicker and they are sometimes constant. At the same time, rear fogs don't work and neither do the reverse lights.
I've taken apart and cleaned the rear light holders, they are in pretty good nick. No obvious signs of wiring damage to the wires that I can see.
This is very annoying and somewhat embarrassing, but not completely unfixable.
What has me stumped though is that when this is happening, I pressed the rear window demister to see if it has any effect and there is a sudden loss of engine power and all the exterior lights come back on, even when the switch for them isn't on. As soon as I turn it off the power is back again and the lights are off. Sometimes, including today, pressing the demister even rectifies the entire exterior lighting fault and the symptoms described above are gone.
Any light that can be shed on this (pun intended; yes, I'm hilarious. Said no one, ever) would be much appreciated. I've searched extensively on here and in the past I've found a few fixes for the lights but the demister thing is not something I've ever heard of before. So if anyone knows of or has found threads about it please slap me with a link.
Ta muchly
Ta muchly
