Got vcds back off my mate - latest log with error sections:
Friday,30,April,2021,15:29:31:41541
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
Ross-Tech: Home
VIN: VSSZZZ5FZGR009866 License Plate: SEATV3
Mileage: 108266km-67273mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZGR009866 Mileage: 108266km-67273miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2370
Revision: 22004001
Coding: 01114012432519090000
Shop #: WSC 00049 770 00124
ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 79F93CB0F87B174384-802C
1 Fault Found:
25126 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:38
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 52 °C
Intake air temperature: 29 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.453 V
Unlearning counter according
OBD: 40
CAN status - engine control module: 0
Cruise Control System (CCS): status: Initialization
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 61335000000399
Coding: 20EE8A9224200975007F060641C9240451249000608224F200 410070C002
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 4B95B678E26755D366-801E
2 Faults Found:
4197 - Rear Left Wheel Speed Sensor
C101C 14 [137] - Open or Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 8
Date: 2021.04.29
Time: 15:09:39
16417 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:48
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5F0 907 426 M HW: 5F0 907 426 M
Component: AC Manuell H02 1001
Revision: 00001K09
Coding: 00100104200100001000000000001000
Shop #: WSC 00049 770 00107
ASAM Dataset: EV_ACManueBHBVW37X 003017
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 3467CD849F992A2B17-8060
1 Fault Found:
459779 - Local Databus
U1030 00 [009] - Electrical Malfunction
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:11:33
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 21051510800445
Coding: 030100F40F087300EA000040000F0001000105000000000000 0000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 75E13080D4637323E0-8020
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A1238290415
Coding: 002000
Battery Monitoring Control Module:
1 Fault Found:
66567 - Local Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:38
Terminal 30 power supply: 12.2 V
Terminal 15: On
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 43859E58CA379D939E-8016
2 Faults Found:
20228 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Reset counter: 48
Mileage: 108266 km
Date: 2021.04.29
Time: 15:15:31
Motor status: 01
System status: Driving mode
Supply voltage: 11.75 V
Temperature: 27.0 °C
KFC: 4F
KFA: 00 04
Freeze frame conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 11.91 V
uAdSensI_SwitchedKl30_xdu16: 11.91 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 48
Mileage: 108266 km
Date: 2021.04.29
Time: 15:15:31
Motor status: 01
Supply voltage: 12.00 V
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 12.08 V
uAdSensI_SwitchedKl30_xdu16: 12.06 V
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 048C000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
1 Fault Found:
13705985 - Databus
U1123 00 [137] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:38
