lard-ajc
112
Leicestershire
I've got a 2.0TDi sport that came without an engine cover.
I know it's mostly cosmetic but I'd like to put one on (got one on my Skoda TDi and don't find it a pain when servicing etc.)
I can only see 1 mounting point at the back of the engine and two holes where I presume two more mounts can be positioned.
Does anyone know the part numbers of the mounts and also the part number of the cover?
thanks very much
andrew
Try Dave at seremotors, look on the dealers links. He got me some for mine when they broke, the original ones were plastic but the new ones are rubber and much better.
they're should be two knobs at the front and a black rubber slide-in damper at the back, have you already got the cover?
if its an older shape octavia and it has nuts to secure it then it'll have the standard tdi engine and wont have the same engine cover as the one you'll need for your leon 2.0lt tdi. the one for the leon is all push fit.
ok, so i just need to get the cover and push it into place?
do you know if there's anywhere online to get one. Any idea of the part number?
