Howie
29
Guildford
Hi All,
I need your expertise, I have a 2007 Leon FR PD170 BMN, recent issues have been DPF light on, limp mode & engine sort of dying then coming back.
After having the DPF cleaned, DPF light & limp mode have gone, but the engine dying has stayed.
Changed crank sensor at weekend ( not the easiest job ) as I had a G28 code, drove it last night same thing happens.
It seams to happen when the car has been driven for 30 mins & cuts at 2500 revs regardless of what gear its in, it dies & rev counter needle jumps about.
Any advice much appreciated.
Usually cooling fan running constantly means the car is in like a failsafe mode as something is wrong. Have you scanned the codes of the car with a VAG reader such as VCDS?
A friend from Work connected it to vagcom & read the G28 code , since then just a hand held reader I borrowed, don’t know any one with it near were I live.
