Ok , as some of you may know im having a problem with 5th gear at the moment, basicly when pressure is applied to the accelerator its fine and stays in gear but when i let of (coasting) you can watch the stick slowly move itself out of gear.
When pressure is applied in 1st 3rd and 5th gear you can see the stick move forward id say about 15/20mm and when you let of it snaps back, im not sure if this is normal? Hence my question.
The garage have told me they are quite confident that its the engine mounts casuing this and more than likly the reason that its slipping out of 5th when there is no pressure on the accelerator.
So could anybody tell me if your stick moves forward in 1st 3rd and 5th. I dont want to spend £250+ on mounts to find that it isnt the issue and end up having to fork out X amount on top for a box rebuild.
Any help would be great!
