Just off out to check the suggested things now.
Bill when you say the cir clips do you mean the black clips with the spring on that you twist and pull back if you where going to adjust the linkage? And also the bracket do you mean the item that can be swapped for the TT version?
no circlips as in the ones which hold the cables to the mounting brkt for the cables onto the g'box
are all 3 mounts the same our the biza ones then phil?
shift mech isn't loose on the gearbox by any chance?
you'd probably have seen it when you wiggled it anyway
