Ibiza FR TDI
Newbie
Sep 5, 2006
53
Down
I'm getting a Fabia vRS front ARB (21mm) fitted in the next week or so.
Is there anything I should think about changing at the same time as getting the ARB fitted? (other than the bushes that came with the ARB)
The car has done just over 30k.
think you need new droplinks other wise the ARB hits something ( driveshaft????) have part nums somewhere , will look
EDIT
god im quick
6Q0411315G connecting link- you need 2 - thank god for receipts
Is there much work involved fitting a fabia ARB?
How many hours labour are we talking?
i think you have to drop the front subframe to get access , so proabably about an hour and a half maybe 2 hours , youll need wheel allignment etc done again after, make sure this is done ,
I'm confused! :shrug:
Tom B, so you think the original droplinks will be fine?
Also, would it be a good idea to replace the droplinks anyway when getting the ARB fitted? And if I do, should I go for the Skoda ones as a precaution?
Got a couple of fitting quotes today for both front and rear (Jabba) ARB.
Both garages I rang wanted £100. Does this seem okay?
