Jun 10, 2022
8
Hi all,
Long time reader, first time poster here!
First of, I want to thank everyone for the great work you're doing here on the forums.
Now, onto the matter at hand.
Got myself a set of Facelift headlights.
They are Halogen with the triangle led drls.
Part # 5F1941016B
I tried connecting them to the existing connector, but the drls don't seem to be working
Any ideas on how to wire them in order to get them working?
Probably rewiring the pins?!
This is my current connector on the car.
And there is the connector on the new lights
Thing is, I don't have a wiring diagram which would be useful!
Thanks for any advice in advance!!
Reactions: JoseKaLeL
I have a guy that could get the diagrams even the bcm ones I’ll search the contact if you want it.. also btw your lights already cames with the connector when you got them ? If yes can I see photos of it cause mine didn’t came with them
Jai le même problème jai codifier le DRL LEUCHT5 et 5 après jai relier le pin 10 à la masse mais pas de résultat
Vous pouvez les monter sans problème le seule soucis c'est les DRL SI vous avez des solution veuillez les partager avec nous
