Sam 95
36
Essex
The EML came on on my LCR yesterday and using the torque app on my phone I get these codes. I have looked around on the forum but could anyone confirm that it is the pre cat lambda which is at fault?
If this is the case would this lambda be okay?
m.gsfcarparts.com/930vg1110
Cheers in advance guys just want to make sure I'm buying the right thing!
Sent from my Nexus 5 using Tapatalk
Other than tell you p0135 is more than likely o2 sensor 1 causing that code i cant confirm the part is right, the company you buy it from should be able to tell you if its right or not, the other code is a turbo bypass electrical fault! Again no idea what the problem is there, prob another one of many sensors or valves to replace! Sorry i couldn't help more!
