First logs
willcooke
Brrrummmm
May 31, 2005
114
Beds
Hi Guys,
I've just been out and done my first proper logging as I think something isn't quite right with my car. (Remapped LC with induction kit).
I'm getting this error frequently:
Code:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
        P1297 - 35-00 - -
But can't find any split hoses and the DV is a new forge one. So, this led me down the broken MAF route.
I've posted my results below, and I'd be interested in knowing if you think there's something amiss.
The peak air mass is 162 g/s - does this sound reasonable? From what I've read this might be under a bit, but doesn't sounds broken.
Also - would you expect the actual boost to read the same as requested at the time of planting the thottle? I assume that the turbo takes a while to wind up to full speed, hence the difference at the beginning of the run, but I would also expect the engine to ask for less boost at the start?
If I use the g/s muliplied by 1.31 I get a bhp of about 210 bhp. I would have expected this to be a little higher.
Here's a log of 003 & 115
Code:
time     rpm     airmass  thrt  ign      time     rpm       load     req     actual
16.7	1880	37.47	100	12	17.1	1960	103.8	2040	1300
17.4	2040	44.14	100	8.3	17.7	2080	115	2060	1390
18	2120	51.11	100	7.5	18.3	2200	124.8	2080	1510
18.61	2280	58.53	100	6	18.91	2360	133.8	2110	1620
19.21	2400	65.67	100	3	19.61	2520	143.6	2150	1780
19.91	2560	73.94	100	6	20.22	2640	148.9	2200	1900
20.52	2720	80.17	100	6	20.82	2800	154.1	2230	1980
21.12	2880	87.53	100	6.8	21.42	2960	160.9	2270	2080
21.72	3040	99.78	100	6.8	22.13	3160	172.9	2240	2220
22.43	3280	109.67	100	5.3	22.73	3360	175.9	2210	2240
23.03	3440	114.08	100	5.3	23.33	3520	173.7	2210	2190
23.63	3640	123.06	99.6	6	23.94	3720	172.9	2220	2220
24.24	3800	119.67	100	9	24.54	3880	166.2	2240	2140
24.85	4000	126.97	100	9.8	25.24	4080	167.7	2240	2180
25.55	4200	132	100	9	25.85	4280	165.4	2210	2170
26.16	4320	136.56	100	9.8	26.45	4440	165.4	2200	2180
26.75	4480	140.36	100	9	27.05	4560	163.9	2190	2160
27.37	4680	145.44	100	6.8	27.77	4760	160.9	2150	2110
28.06	4840	146.47	100	11.3	28.36	4920	158.6	2150	2090
28.66	5000	150.72	100	11.3	29.07	5080	158.6	2140	2100
29.37	5160	154.22	100	11.3	29.67	5200	157.1	2150	2080
29.97	5280	157.42	100	12	30.28	5360	156.4	2150	2040
30.58	5400	159.69	100	10.5	30.89	5480	153.4	2070	2010
31.18	5520	161	99.6	12	31.49	5560	151.1	1990	1980
31.78	5640	160.75	100	11.3	32.08	5680	149.6	1980	1950
32.38	5720	162.28	100	9.8	32.69	5800	146.6	1960	1930
33	5840	162	100	10.5	33.3	5840	133.1	990	1750
33.6	5840	3.94	5.9	12	34	5720	11.3	990	1100
Any pointers would be gratefully received.
Is there something else I should log as well, perhaps timing pull?
Cheers, Will
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Replace the MAF, its knackered.
Remapped K03 should read around 150g/s
Remapped K03S should read around 180g/s
Remapped K04 should read around 200g/s
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
surely that'll depend on the map?
158g/s reliably from a k03 on std kit disproves that theory.
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Rough figures, for a standard car with just a remap. Do you think they are off?
Sure a sorted Ibiza Cupra R with lots of bolt on bits done could probably pull that.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think that your numbers are off & his map is a tame one
'normal' maf failure flatlines at a given airflow, but this one pulls to the top of the logged rev range, rather than about 4000rpm & plateauing off.
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Also, ive got an SPS3 coming through the post soon, on a standard 225 engine, bar remap and 007p, what boost and timing would be a good place to start off from?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
sorry, can't remember really, but not too much boost, and not too much timing 6/6 is normally what most people should run
SWANSWAY CUPRA Dealership
