seattoledotdi
Hi
all
Have now bought a vag com and the first read out is attached. hope someone with experience will guide me through it.
The main concern is the esp light but I would like to make sense of the other faults as well.
thanks in advance.
Also if some one can tell me where the abs pump unit is located in a toledo tdi 2005.Thursday,26,February,2009,13:14:49:02165
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
Mileage: 30730km/19094miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HM HW: 028 101 227 8
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: SEZ7Z0E3020592
Coding: 0050078
Shop #: WSC 06402 785 00200
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 G HW: 02E 927 770 AD
Component: GSG DSG 041 0922
Revision: 04004010 Serial number: 00000503230563
Coding: 0000020
Shop #: WSC 44551 111 44551
2 Faults Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Reset counter: 1
Mileage: 29310 km
Time Indication: 0
28775 - No Communication with Gear Selector Module
U0103 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 24
Mileage: 29358 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0004850
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 006 0203
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003336121
Coding: 81880F2700041000001E00000100000000007F0B5C
Part No: 5P0 955 119 B
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 06402
2 Faults Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 9
Mileage: 28438 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 29358 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: S9 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0EWZC2
Coding: 0021305
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 034 0070
Coding: 0012042
Part No: XXXXXXXXXXX
Component: E0221 004 0060
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 923 A
Component: KOMBIINSTRUMENT VO3 0616
Coding: 0002401
Shop #: WSC 06403 785 00200
1 Fault Found:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001056028E40
Coding: 3F3F0340071203
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 29358 km
Time Indication: 0
Date: 2000.00.00
Time: 12:10:04
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0616
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2432
Coding: 0000656
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000DC2D0005054C5F863000CC
Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1T0 959 702 C
Coding: 0000656
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P2 035 152
Component: Radio BNO 0035
Coding: 0040400
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2406
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
End ---------------------------------------------------------------------
hi
thanks fore the response
I did clear them and but they are shown again. The esp light is on all the time. But I dont notice anything unusual when driving.
Have you already tried to clear codes? Owing to the intermittent nature of the codes, I'd try clearing them and then see what returns.
can you please assit. Ive just spend a lot of money on the official vag com from Roos Tec but some of the codes dont appear on your code list.
I'm not working from the office - I went home sick today - miserable head cold! So, I don't have access to my colleagues or my technical stuff.
From the scan you have posted, something is seriously messing with the communication between the modules in the car. Or, the CAN gateway has been messed with and the coding for it has been messed with.
I was going to refer you to the Ross-Tech wiki for more information on your codes but I take it you have already gone there to get what assistance you can get.
Have you played with the coding of the modules? Do you have more history as to how this all came about? Is the car running well?
I am going to send an email to a colleague to see if he might be able to suggest a course of action.
Hi and thanks again
The car runs ok. I bought it in 2006 with 11000 miles on the clock. I use it very rarely and therefore its only done less tha 20000 miles since new.
It drives ok and its only recently that the esp light has started to remain lit all the time. The esp switch will not turn it off. The engine management light was also lit and after I removed the fault codes that has not yet come back.
The car does spend a lot of time parked up but the battery has always been able to start it without assistance.
sorry to hear about the head cold. hope you get better soon
Sorry just to add I have not interfered with the system at all. just done a scan. and removed the fault codes.
Just to add
whilst driving sometime ago the audible bleeps (3 loud ones) began to sound at fairly regular intervals. after some research I topped the coolant level to just above the high mark and the bleeps stopped.
Bruce asked me to take a closer look at this, so I did some checks and updated/added some codes in our WIKI. First off here are some links you may wanna look into to understand what the individual codes mean.
02 (Transmission):
http://wiki.ross-tech.com/index.php/18255/P1847/006215
http://wiki.ross-tech.com/index.php/28775/U0103/049411
03 (Brake Electronics):
http://wiki.ross-tech.com/index.php/01435
This code is not unusual but as you can see in the suggestions what to check quite often the sensor is at fault but since the sensor is part of the ABS unit the whole unit needs to be replaced. Seat (as well as VW, Audi and Skoda) usually offers a warranty extension, did you buy that extension when you bought the car as well? If so, just drop it off at the dealer they will most likely take care of this. Working on the brake system is not necessarily a job you should do at home...
09 (Central Electronics):
http://wiki.ross-tech.com/index.php/01800
http://wiki.ross-tech.com/index.php/01321
16 (Steering Column Electronics):
http://wiki.ross-tech.com/index.php/00888
17 (Instrument Cluster):
19 (Gateway):
72 (Door, Rear Right):
http://wiki.ross-tech.com/index.php/00935
Some additional comments after all, when you're having problems like this and cannot get an answer in the forums in time you may wanna drop us an email with the scan and your questions. We usually try to reply within one business day to those mails but may not be able to provide the same service in all forums we participate in. Last but not least an additional note, we can understand that you don't wanna publish your VIN in a forum but nevertheless it has been proven to be helpful to have at least a slight information when exactly the vehicle was build. Our suggestion therefor is to post the VIN but X the last 3-4 digits. That should give you enough privacy while others can still figure enough details from what you give them. ;)
thanks for the reply
Ill study the links . i take on board the other pointrs you mentioned.
