does this work the same for a sony wiring loom..
i have 2 blues and a blue with white stripe..
1 has "att" on it which i think is the phone lead (light blue)
1 has "amp rem max 0.3a" (blue /white stripe)
and the last one is connected from the sony connection to the black iso connector.(dark blue)
often wondered why sig was crap
if i remember, on the car loom, the blues are remote live switch on, eg for the external sub amps or T.V. or anything else that needs a signal to turn on. Blue and white is for the speed variable auto volume adjustment.
Think its right, someone will either confirm or deny my knowledge. good luck.
I think the sony wires are backwards, or I may be reading the post wrong
att - telephone mute
amp rem max 0.3a - remote switch on, tells the auxilliary that the radio needs it to turn on.
Hope this helps, hope i'm right!
Where do you get these aerial amps from? gunna fit my Alpine 'cos I'm fed up at looking at the bog standard HU!
Anyone got any pics they can post so I know what I'm looking for?
You'll need one of these:
I got mine from Halfords, about 5-10 quid IIRC.
Works a treat on my Alpine.
are there any alternatives to scotch clip connectors? i used these years ago, but weren't the most solid
i want an easy way to connect various wires like this blue aerial amp one, without stripping wires and etc
