Hello!
I am waiting for a K04 kit from a TT 225 APX engine to arrive.
Does anyone know if this will fit bolt on? Thinking of the oil/water pipes and pipes to the intercooler (because they don't go the same way as on a TT/LCR)... What will have to be modded?
I have a 2,5" Exhaust from cat, but I will probably need cat from TT or LCR. Thinking of bying a supersprint.
Also waiting for a Forge FMIC.
The kit contains (if I have got the translation right - see the picture!)
K04 Turbo, wastegate with oil/water pipes, hoses/pipes, fuel injectors, downpipe, manifoild...
K04 Abgasturbolader / Interne Wastegate mit Ölleitungen und Wasserleitungen, Druckschläuche zum neuen Anschluss an den Turbolader und an die Ansaugbrücke, Einspritzdüsen, alle Halterungen für Turbolader und Druckrohr, BlowOff Ventil und deren Schläuche, Flamm/Fallrohr zum Anschluss an die Kats zum Turbo, Abgaskrümmer zum Anschluss an Zylinderkopf und Turbolader, Schellen und Schrauben sowie das abgebildete Druckrohr
its not the same i think , but with the beezer we had to let somebody make 2 oil pipe's, otherwise it didn't fit
