Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Will I be ok to (attempt) to code a key without 'power' in the origional key?
Yes, as long as the transponder is working
Ah right thanks. is there any way I can test this? It starts the car fine and opens the door with the blade just cant use the buttons on the key
Frequency is just on the side of the key mate
will be 434 or 433 with MHZ after it
Do you have a pic of where it will be ?
all mine says on the side of the key is CE
Then on the key blade it says W3 HAA
thats strange mine doesnt have it ?
key is not old at all well not that i know of car has just done over 55,000 and its 56 plate , can you find out by reading with vagcom do you know ?
