Fog Light
jatinder
Looking for a job member
Aug 15, 2005
77
Clayhall, Essex
Just A quick one really. My cupra has a bulb in the passenger side rear fog lamp, but its not working, are they supposed too? As it has a bulb I thought it should.
Any ideas?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
your turning the headlights on the pulling it out right? if not they could have been put in there after it was built and maynot be connected?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Sorry i miss read i didnt read the *rear* bit :rolleyes: no i think its only supposed to be one rear fog light my 16v is the same, i tryed a new bulb in both and one didnt work so i assume that how its suppposed to be.
hopkinsgm
Do-doo-be-do-do-dooo
May 25, 2001
2,030
Swindon (occasionally)
As standard, it would have only had a single rear fog lamp. It's a bit of a moot point as to whether the passenger side lamp should work for the MOT if a bulb is fitted. Simplest solution is to take the bulb out. As others have mentioned, a feed for the passenger side lamp can be taken from the drivers side lamp easily enough. I'm guessing a previous owner put a bulb in "just to see", found it didn't light up and just left it in there.
SWANSWAY CUPRA Dealership
