Foglights
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
yes you can get a fog light kit from the dealers and you can fit it yourself if you are a bit af a handy man or get the dealers to fit them for you, I have done a kit on a mates car
the STICKERS that you have on your mirrors are replacement mirror covers
you can remove them and fit plain black ones or pre painted silver FR ones that i'm pretty sure will match your car, both black and silver ones are about £10 a pair from the dealers
If you want to sell the chrome ones I will have them off of you for £15 if they are in good nick....;)
Rosco906
1,445
Burntisland, Scotland
Anymore detail mate. anything a bitch to do? And how much was the kit? I did the foglight kit on ma renault and that was a 7/10 job.
Im an apprentis mechanic so easy enuf.
Let me no when u can. Thanks mate
Also if i can get the chrome 1's off on 1 piece thats ok with me.
gazjones
fog lights are very simple to fit took me about 2 hours only difficult bit is feeding the wires through the dash
Rosco906
1,445
i asume you get the new headlight switch with the pull out fogs etc.
Anyone know the price on the kit?
Also what other simple styling things than can be done.
Going to put mirror caps on(silver) Bee sting areial instead of the antenna
lower it and 18's.
is the bumpstrips just rubber attached to it or would it require smoothing?
Thanks for your time people
Nath.
Jan 1, 2006
8,619
16
don't remember the price of the foglight kit but it was quite easy to do (2-3 hours max
the hard bit was removing the old light switch and threading the cables through the bulk head
:rolleyes:
gazjones
to remove the old switch you push the knob in then slightly turn it clockwise then pull it out!
Ric 2001
Need an ID-ten-T form
The reason I was given for having the washers was to keep the lenses clean, as any dirt on the lens can cause deflection of the beam, and the possibility of dazzling other drivers. This is why in a Xenon equiped car you cant adjust the beam level manually (on dashboard) as in Halogen cars, come with auto-levelers.
Also its required by law. But aftermarket HID kits (which can cost alot), do not require levellers or washers. - something you learn everyday.
sikedellic
Does the foglight kit come with decent instructions or is it a case of work it out yourself?
gazjones
its great for fitting instruction but nothing much on the wiring though pretrty easy if you have a multi meter though as you can find the terminal that gives powr when the fogs are turned on!
