Hi all I can get 2nd 4th and 6th gears but I can't get 1st 3rd and 5th
Any ideas what is causing this?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
set in wrong pos was it ok before you put it on?
Was the gearlever locked with a pin while you set it?
Yes used the Forge pin to lock the gearlever, then I had to push in this pin in the engine bay to lock the gearbox
tbh with abit of driving it seems to be going into the top position gears easier now.
have you just put it on? and what was it like before you did it was the box ok ?
