Lee M
Hi All,
Recently fitted some new upper hoses on my LCR (Kit: FMK008). I had a real mission installing the one between the inlet manifold and the MAP sensor pipe.
I had to cut it down because it was much longer than the original hose and then it would not go over the inlet manifold.
I eventually got it on but most of the hose bends (on both hoses) are now quite out of shape especially the one closest to the inlet manifold.
Has anyone else had the same problem and if possible have you got any pics of your install. I've contacted Forge because they are normally very helpful, but a bit of info from you guys who've already fitted them would be great.
Lee
Ok Guys,
I've been asked to send these back to Forge as mine my hoses are part of a batch with a bit of a manufacturing problem.
So back to the standard ones for a while.
Lee
Always nice with hoses to be too long and not too short, you can always chop them down to fit
Im sure you will be out pretty soon fitting them again
