@DEAN0, which OBDeleven kit did you get? Any chance you could post a link?
The Lane Guidance being on everytime you start the engine is really annoying so it would be good to turn that off and the ACC issues.
I went with an OBDeleven PRO ( you need the pro version to do long coding )
Bought it here - https://albionshire.co.uk/product/o...n-nextgeneration-scanner-for-ios-and-android/
For ACC I turned off the overtaking on the left - but sometimes - when front assist is not available - you still can't use it.
So i now have three options available - ACC, Std cruise control ( works without front sensor ) and speed limiter.
For lane guidance - you can set up one of the shortcuts on the screen so it is a simple one click to switch off
same with the stop/start.
just pick up my 190 V2 in black looks amazing, the mpg shocked me abit, but reading here I see its just time to allow the engine to settle.
For roughly the same use
First 700 miles I struggled to get over 26mpg
700 to 1000 it went up to around 30mpg
once it got to 1100 it showed 32mpg ish
A few have said it takes a good 2000 miles to loosen up.
