Nick_J
376
Milton Keynes
www.facebook.com
Hi guys and girls.
As the title suggests, is the clutch the same on the Fr Tdi PD as on the Cupra tdi PD?
IF so, surely remapping to 180 bhp 270-280ft lb of torque shoudnt be that damaging to the clutch as long as its driven correctly?
Nick
You only really need to change the clutch for an uprated one when you get closer to 300lb/ft.
So long as you try not flooring it at lower revs the clutch should be OK.
pretty sure its the same clutch, the pd160 is only running 253lbft as standard, but most bring up more like 260-270lbft on RR so probably safe around that mark.
the pd130 produces 229lb.ft standard and the pd160 produces 243lb.ft [i think.]
Most produce nearer 250lb.ft but once remapped they will be 280lb.ft+
The clutch starts to slip at 290 lb.ft
Thats the only thing worring me about a remap. I thought id need a new clutch. But if yous are getting 296 without slipping it seems the standard one will do :)
Petrol Ibiza Cupra is different to the PD 130/140/150/160/160 clutch.
Ibiza 1.9 Tdi 160 Cupra ( 160bhp/ 118kw ) ( Eng ASZ / BPX )
( Requires flywheel No HF9287 )
Road 60-4610 70-4611 40-4621 24.2 x 23T
Ibiza 1.9TDi ( 130bhp/96kw ) ( Eng:- ASZ / BPX )
( Requires Flywheel No HF 9287 )
2002-> Road 60-4610 70-4611 40-4621 24.2 x 23T
Ibiza Cupra Sport 2.0ltr 16v ( Eng:- ABF )
1997-99 Road 60-4856 70-4606 40-4717 22.1 x 28T
Mine slipped if provoked, has been remapped for 45k. Now with the cold weather with us, its slipps in all but 1st gear :(
New clutch in the new year I think!
My Cupra TDI is standard and I can spin the clutch up very easily in cold conditions if driving in high gears at low revs then accellerating hard. ie not working up through the gears.
If you go through the gears you may be ok, however you will probably need to change the clutch sooner or later.
may as well chuck all my standard cupra running gear got
clutch, flywheel, injectors, maf sensor, ko3s turbo, turbo intake pipe, standard airbox, maf housing, just rotting under the bed :lol:
maybe selling up as well :cry:
on stage 1 clutch used to get clutch slip dont know how some of you put up with it! its so annoying makes the car even slower imo! cant use the power ect frustrating when your trying to overtake as well! but that got sorted ages ago thank GOD!
im buying an ibiza 130 sport remaped to 185 bhp and 304 nm of torque!, it has an organic single plate clutch, all i know about the clutch is the Jap drifters use it! are they a long life clutch that take the punishment from the power????????????????
I think somebody has been telling you a load of shite mate. You need to fing out the name of the clutch and some proof that it has been fitted by sounds of things if they are talking crap like that.
