Spot on and I've not been able to find an LED equivalent so far. There is a brighter 'xenon like' one around, but I won't bother !
How many do you want
http://m.ebay.co.uk/sch/i.html?_nkw=Bay9s+led&isNewKw=1&sqp=bay9s+led&LH_PrefLoc=2
Is the DAB only affected when reversing?
Given how shocking my dab signal strength is that wouldn't be a big issue. I can't seem to get any stations anymore.
Sent from my SM-G900F using Tapatalk
I know in the Mk3 the reverse led doesn't flash as if its canbus checked When I had the same led in the LCR it used to go off like a camera flash when you first started the car, 2 or 3 times. Made me grin but then that doesn't take a lot...I've had a few leons and it seems to have got progressively worse with each one, my new one is so bad it looses most DAB stations, often for many miles, depending on where I am in the country, stating to wonder if it's not only the car, but whether they have downgraded the DAB transmission signal strength in some parts of the country, as on my first early 2013 mk3 I got great DAB reception all the time.
Also don't know if it's already mentioned, but there's no need to pay more for a can bus bulb, the reverse light isn't monitored so doesn't matter if it's can bus or not
I need to get one of these!! Couple of quick question's though;
Does changing the bulb effect the DAB signal..?
Is it just a case of swapping the bulb or do you need to change/program via VCDS..?
Thought I'd order one of these to avoid running over next door's cat when I back out of the garage, but found they are out of stock of white ones! Guess you guys have cleared them out!
Difficult to see why they fitted such a poor reversing light set up on the Leon - even the Mii has got a pair!
Anybody using these leds:
(link removed due to my membership restrictions) - for rear indicators
(link removed due to my membership restrictions) - reverse light
Yes they are, which is why I wanted to get rear ones, so they match
Number plate light, rear and front fogs?
I'm not sure my number plate lights are. I'll check at some point.
I don't have the winter pack, but I'm not sure if I'll change the front fogs, as I don't really use them (I'm not a fog light w*****... My biggest pet hate) but then the difference in colour to the LED healights when I do use them affects my OCD!! lol
