I can't seem to find this answer anywhere so I'll ask what I'm sure has been asked before already:
Am I right to understand that there are 4 possible strut braces that you can fit to an LCR? Front and rear, upper and lower?
Also, I've read some people say that the front-upper one stops the car from under-steering as badly, yet in another thread I read that just having the front brace will cause the front end to be too stiff and causes more under-steer.
So, if I could only get hold of one at a time, which order should I get them? And is there anything else that should be considered in between (ie should an ARB be fitted between fitting a certain pair of struts)? Already looking at replacing the engine mounts etc, where should this fit in to the process, if at all?
Cheers guys
Cheers guys
