AndrewJB
Friend to SEAT UK & Cupra Racing
Aug 16, 2007
11,163
483
Maranello
Right Guys my front right has been knocking for ages but its getting annoying now, if i go over speedbumps or cat's eyes it knocks
Had a quick look at the Droplinks, Pulled them etc they feel ok so i thought top mounts but might aswell replace drop links aswell
So what aftermarket options is there out there for Droplinks? Im also under then impression that theres a new set of Audi TT top mounts that can be fitted to the MK5 Chassis (tfsi_mike sent me a link ages ago)
Check ARB as well. They are over looked many times and they tend to knock over bumps. As far replacment - OEM are my recommendations. They dont cost much more and those are the once that come with vehicle.
I had a look at ARB, i looked for any kind of damage to the paint on it where it had been banging but nothing
Ditto re the knocking...
Raised it on my recent 100k service, fault was found (the knocking noise was noted I should say) by the mechanic (fitter), but no resolution yet, they want to have another look next Tuesday as its's in for replacement disc & pads, shall report on any findings.
I did find this last week & I've sent them a copy to pass onto the mechanic for information, worth checking...
http://www.seatcupra.net/forums/showthread.php?t=315436
I've not had this on my Mk2 but did on my Mk1 LCR. I had a look at the drop links (which looked fine) and they were as tight as I could get them. No improvement. In the end a mate swapped the drop links for me cos it was the cheapest thing to try and it cured the problem.
my car is stalking to creak, not neccessarily knock, from the rear. When I go down bumps more than up bumps it sounds horrible and like its coming from my boot (but it isnt) I am assuming its my upper shock mounts, can anyone confirm?
they're easy enough to check, you can tighten them without even taking the wheel off. Knocking usually is caused by loose shocks, so it more than likely. But as is the way with working on cars, nothing is ever straightforward
I had a loud knocking from front end, turned out to be the arms from the steering rack to the wheel, both were well worn. Front wheel had a sh!t load of play in it.
Cost £120 in VAT to get fixed, parts labour & tracking.
Funnily enough, the garaged that MOT'd it gave me an advisory on the rack last year, saying the whole thing had to be replaced at a total cost of £1400. Glad I left it!
When you did your checks, did you raise your car or was it on wheels? Drop link should be checked while car is on wheels. Otherwise if you jack it you pull antiroll bar and many times its harder to notice any play in them. Control arms, toe arms, ball joints, springs & shockers should be checked while raised - antiroll bar links and bushes - ALWAYS ON WHEELS!
Overlooked by many places.
If you any where close to Leeds joins us here: http://www.seatcupra.net/forums/showthread.php?t=336251and have it check out.
Did you ever get to the bottom of this bud?
ive had a look at springs,Shocks nothing appears broken or loose
Top Mounts didnt appear loose but might get new ones anyway
i had this on my 2010 Leon 1.2TSi, or it was a similar thing, I only noticed it over speed bumps though.
I took it into the dealer and they said it was the bearing mounting on my shocker? It was replaced under warranty anyway, don't know if this will help though.
Sam
Have had this for about 1 year, replaced the drop links, still doing it, then in october I fitted new OEM top mounts both sides, still doing it :(
Have just decided to get on with it and live with it
