Afternoon folks,
Two questions please!
1) Front wipers - driver side - the wiper arm rubs on the underside of the bonet, and has warn a patch into the plastic nut cover and some of the bonet. Visibly it clearly stands out too high.. you can see a fair bit of the spindle shaft compared to passenger side.
I've taken the plastic cover off (from the area where the ECU is housed, inside the engine bay) and can see that the spindle seems to poke through too far, but can't see any adjustment, the wiper arm assembly seems to be bolted to the body work at both sides.
Anybody got any ideas on how to adjust it down? it's always been like this..
2) front windscreen - is it supposed to be bonded in some way to the rubber/plastic which runs across the bottom? Mine isn't.. It touches the glass, but comes away when you press it, although the ECU area seems free of corrosion, at the minute..
