I think he is powering it via obd socketThat’s strange. Have you tried a different feed? Or a blank fuse would be even better. The feed you’re drawing from could be causing the errors... I’ve seen that often
A small pry tool and it just pops off, there is enough play in the airbag cable so you will be okThanks @steviekek , I’m just doing this now. Glove compartment came away easily thanks to your explanation and helpful photos! But now I’m stuck - what did you attached the negative spade to? And how do I get access to remove the side panel? Looks tricky with the airbag key... not convinced I want it going off while I’m fiddling...![]()
Yes! Perfect thanks! Came away easier than I expected. And there was space for the bundle of excess wires as you said. ThanksA small pry tool and it just pops off, there is enough play in the airbag cable so you will be ok
Once you take the panel off there a screw that you can attach to
Hope this helps
Hi Steviekek Can you tell me is the accessory socket in the arm rest is live when IG is switched off? I hope so as I am just going to power my dash cam to it, save me the bother of attaching it to a fuse.Anyone have a Fuse diagram for the formentor?
I know they are listed in the manual but looking for the diagram of the cabin ones in particular
Cheers Bill
PS. Not long now till I pick up my New Formentor!
HiHi
It’s something I’ve never tried and haven’t even got anything I could plug into it if am honest!
Apart from lowering the glove box it was very easy to hard wire it using a next base cam and kit
Is it tomorrow you get the car?
I will keep an eye out for you. Ive still not came across another one yet...hope all goes wellHi
It's all happening this week, Second Covid Jab today, and collect my new car tomorrow at 12.00pm!![]()
The socket in the arm rest stays powered for around 30 seconds once ignition is turned off, then goes off all together.Hi Steviekek Can you tell me is the accessory socket in the arm rest is live when IG is switched off? I hope so as I am just going to power my dash cam to it, save me the bother of attaching it to a fuse.
Cheers Bill
Happy New Car Day BillThanks. I will have my private number on the car so it wont show 21! but will show WILL![]()
Thanks Steviekek Nice day for it as well! That's good about the socket. I will use it to power my dash cam. Cheers BillHappy New Car Day Bill![]()
How did you get on7Thanks Steviekek Nice day for it as well! That's good about the socket. I will use it to power my dash cam. Cheers Bill
Enjoy, I found the system a bit overwhelming at first but soon got used to it, I upload using the tapatalk app for iphone but I think you need an image hosting site for picturesGot It! Still trying to work out some of the settings, managed to connect my phone and Apple play, cant connect to the Cupra app for some reason? The system did update its self!
How do I insert a full size picture to my comments? The attach files below button only uploads a small blur photo!
Hi Steviekek Wee picture of it in my garage in the new Media section above.Enjoy, I found the system a bit overwhelming at first but soon got used to it, I upload using the tapatalk app for iphone but I think you need an image hosting site for pictures
Looking forward to seeing a few pics
