If you can find where go CAN high wire from cluster to ecu ( speed signal) .
I look Autodata , but scheme is bad .
And can you give a direct speed signal from cluster ( white/blue ) to ecu ( ecu pin/wire ?)
thanks
Hey, so I tried to log the 4 speed wheel sensor all the 4 sensor got the same speed as the speedometer, I tried to found some wire issue, can't find , it's so annoying
Wiring pinouts
Cluster T32/7 = Canbus Low (Orange/Brown)
Cluster T32/8 = Canbus High (Orange/Black)
Connect via Bulkhead to ECU through white plug at Pins 6 (low) 9 (high)
It then joins the ECU at pins
T80/31 + T121/60 (High)
T80/32 + T121/58 (Low)
Hi all .
in one service my problem is fix, the problem is one cable is cut in a bundle of cables before bulkhead.
exactly where one turns bundle cables cable interrupted bundle.
can't find it yet any one?. in vcds there is block 4 in engine that show the vss while am driving the block shows 0 and not the speed that the cluster show or the abs wheel sensor, I don't know where to go with it the mechanic
said he gave up
