Garrett or IHI
Apr 28, 2003
2,624
ryan_s3 said:
Is is worth changing a turbo out for 20/30bhp?
It is if the same turbo makes another 70bhp than the other at the limiter. There only may be a peak of 30-40bhp its the space under the line that counts.
Look at the links between CC's car and Bills look what each car makes at 7800rpm. Its not 20-30bhp the vf34 is on its arse.
Casper
swoooooooosh
Jul 7, 2005
125
That's what have i been asking myself lately :) Just the ko4r fails after 5500 rpm straight on the face where 28rs could go nicely past 7000. The drivability is not so good with the k04r since the torque comes in too brutaly and is not so good for track driving. I am satisfied with my setup as it is but would like to try sth. else with a bit more progressive power/ torque buildup and a couple of more horses -the 28rs seems perfect for the job, also considering the price which isn't too steep IMO.
Casper
swoooooooosh
Jul 7, 2005
125
@ Gary; Jup it is all about the area under the curve not just the peak values. Mine peaks @ 5386rpm with 302,6hp but before the 7200rpm line there are available around 260hp. Wonder how much more hp would it be with the 28rs at the 7200 line.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Madmile said:
I'll let you all know how Jabbas new turbo fairs on my car i have scrapped the idea of a Td06 20g and have decided to try there 380bhp turbo. The hope is similar performance to Bills old Pe1820f basically only a peak power gain of 40bhp ish but instead of making 260bhp @ the fly @ 7800rpm were hoping for more like 340-350bhp.
Bills Pe1820f flywheel from awesome
http://www.awesome-gti.co.uk/rollingroad/graph/rr.xmas2_29.12.05/brockbank2.jpg
Custradcupras from awesome
http://www.awesome-gti.co.uk/rollingroad/graph/rr.scn_10.12.05/custardcupra2.jpg
You can see how the vf34 aint making the power i want to above 6500rpm. Jabbas new hybrid will hopefully fill the gap at the top end. It should also spool a little quicker than the Pe or at least as well. The results should be in by Mid October.
1900cc and big port also on mine
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Madmile said:
The Pe was able to break Bills box the Td06 20g would probably be over stepping the mark.
The VF34 also broke the std 2nd gear, but that was heavy Cadwell use
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
for me it would'nt be worth the ££ for return.
£1200 of new turbo and I want some decent power hike to justify the bother of doing it at all.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
when comparing VF34 to my PE1820, also remember the engine was 1781cc then 1900cc with big port cylinder head and 3" DP change also.
not just a turbo change and comparison
Apr 28, 2003
2,624
The new turbo is supposed to more effcient than the Pe1820. There saying upto 390bhp on largeport and upto 380bhp on smallport. Peak figures aint my aim just more sustained power. Time will tell. I guess 370bhp is the aim.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
they done any yet to have dyno's to have look see?
Apr 28, 2003
2,624
Jabba only ever let you know what they want you to. They seem to keep things under wraps these days. There web site claims upto 380bhp on smallport we know vf34.18 is good for 340-345bhp a .20 housing and decat would prob see 350-355bhp the vf34 is prob around a 35lb/min compressor wheel. Add a bigger comp wheel and i cant see the extra 20-30bhp being hard to find more so when wilko was saying v-power alone can allow upto 2 degrees more timing. Like i said its not all about peak power its the sustained power above 6000rpm i am looking at.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
as ever seeing dyno's to back up figures helps people see what the delivery is etc... just the same as digging up previous dyno's as comparisons.
I guess some will take the plunge, go to a RR days somewhere and the results can be seen for themselves, whatever they may be.
watching this space.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
exhaust housing is the poor item, including P20 housing.
restrictive and temperature limited
