redone it using a diferent pic and its working alot better although still got a delay(shorter than before) with the discharge but only in the higher gears
GUYS LOOK AT THE OTHER PICS ON HERE,LOOKS YOUR ONE WAY VALVE IS WRONG WAY,HENCE NO BOOST????? SURE SHOULD BE WHITE PART HEADING UP WARDS(POINTING TO THE BULKHEAD![]()
... is that infor within these 12 pages??
If only you could moderate your own topics, therefore be able to remove those posts that are not on topic...
Resistor is easy. 330watt 10hm, cut off the solenoids if theyre not being used any more and solder in their place the resistors. Simple.
I have your address for paypal payments.Dave, had a quick look and i cant find anything really.
I'm sure i have some spare resistors i'll see if i can find them.
Sounds good...... how?You could always make a bank up of 110 watt ones.
