Over time I've gradually been getting increasing noise from my gearbox, and before I take it to the dealer I want to be armed with as much info about possible causes as I can.
Symptoms:
When starting from stone cold, and then until it's fully warmed up, I can hear a clattering noise from the gearbox area - whilst sat inside the car, with engine idling, and foot off clutch.
It sounds like someone's chucked some pebbles inside the 'box - a random kind of clatter, not regular.
If the engine is idling smoothly, it's only audible if I repeatedly blip the throttle very slightly to cause quick (but small) changes in engine speed.
If the engine is idling lumpily, it's audible without having to do this.
If I just put a bit of pressure on the clutch to take up slack, the noise remains.
If I push the clutch down past biting point (so the gearbox is disconnected) the noise goes away.
When fully warmed up the noise goes away.
I've mentioned this in the past, and it was suggested it could be the dual mass flywheel on it's way out.
But just wanted to know if it could be anything else - gearbox bearings, clutch release, etc etc
Also, has anyone else noticed this ?
Symptoms:
