brush.
Does anyone know how i can run a wire from the engine bay to inside the car? I want the wire to end up at the fuse box... :think:
After 4 hours of fiddling today with it, i managed to get a power cable from the battery in the engine compartment inside the cabin. Its actually really close to the fuse box.
I got inside beside the left-side chassis, then i found an opening leading inside the car. ill make some pics tomorrow and show you ;)
I'm guessing by the photos the car is RHD and has the fuse box on the right and not left?
Anyway, I've ran a boost pipe - pipe down the same route as the bonnet opener cable.
If that helps.
Chris
not sure where it was so i went the more "easy" way :p
as for the car make, ive no idea what "RHD" means :p i got the steering wheel on the left side though :p
RHD = right hand drive
Thanks for the photos! I'll let you know which way I end up going.
What I'm trying to do is wire up the heated windscreen washer jets I bought from ebay. I want to wire it so the heated nozzles come on when I switch on the heated wing mirrors.
There is an earth and a live to be connected. I'm hoping that the live I need to connect to is somewhere in that red circle on the first pic I posted. If I can work out which wire comes from the heated-wing mirror fuse, then I'll solder onto that wire. Does this makes sense? Feel free to let me know if you think I'm going to break something :D
Wait - that's wrong. For the mirror switch to control the jets, I would have to connect them between the mirrors and the switch. So that's probably in the door somewhere.
