golf mk4 V5 lambda problems
wild willy
2,323
Wales
My dad has a golf V5 mk 4 and has a dash warning light illuminate. i scanned for fault codes and identified the following. I'm guessing theres a leak in the down pipe or the oxygen sensor needs replacing. can someone tell me how many probes a golf has and which one is this fault code referring to. cheers in advance.
Controller: 066 906 032 AK
Component: MOTRONIC ME7.1 G 0005
Coding: 00033
Shop #: WSC 01271
WVWZZZ1JZ3W285953 VWZ6Z0B0293237
2 Faults Found:
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
Stan 24v
421
Blackpool
The V6 has 4, 2 before the CAT and 2 after. I would assume the V5 is the same. However, either the pre or post cat could be faulty, and it could be knocking the other one out and giving you a spurious code. Is your car overfuelling/under fuelling? Any other symptoms ie juddering
