MGH74
47
I've done a quick search and nothing comes up that seems to fit with what I’m experiencing, so hoping some others can shed some light?
Outside Temperature reading has gone high, over the past couple of weeks it thinks the temperature is hitting 30+ degrees, fluctuates a bit, but never drops below 26. Unsure if the sensor has died or if it has moved? Anyone know where I can locate it?
DAB cuts out when I turn on the heated rear screen. Discovered this on Tuesday when I had to defrost the frozen windows. All DAB stations lose signal, turn it off and the sound comes back again. Was fine last winter? Any thoughts.
The dab boosters are in the tailgate and the antenna are part of the glass.
mine cuts out when indicating and turning right for some reason. i know its not the mib unit as i have gone from mib1 to mib2 and it still does it.
it will we be interference of some kind more than likely how close the wires are to dab cables. my dash cam was doing it for a while when i had a different usb charger once i swapped it it stopped.
i have bought some magnetic ferrite cores to wrap around some cables to see if i can cure it but no idea which cables i should do.
