a good one won't be cheap
my father in law bores out TVR & dragster engines for a few firms locally... a good job takes longer to do (more passes etc) so will cost more (at least the labour rates aren't that bad)
totally know what you mean mork. hence why its not easy.
would your father in law be interested? if hes any good ;)
thats great mork, cheers
does anyone know if i can ditch the whole oil to water cooler? the square ali unit that the oil filter seals against.
i want to loose it as im going to run the mocal sandwich plate and cant see the use of it.
just wondered if anyone knew if it did anything other than cool the oil?
im aware i will need to make a new oil filter feed pipe/mounting bolt
thanks
thanks
Yes you can ditch it, have done this before (on my vr also) as they can be problematic, just needed to shorten the shaft iirc, best done on a lathe;)
The mocal will be more than sufficiant (13row) on the 1.8t, so you can ditch the stock one and yes all it does is use the water jacket to cool the oil, which in turn heats the water:D
I know someone who builds 1.8ts and races them in the VW cup who would prob build it for you, very worthy of course, but would be a 'build' and not necesarily a machine shop if you get what i mean?!. He's in Essex.
do you have details of your friend please jon?
i have 2 lathes so i will do that! i never really thought of modding the current bolt/pipe.
cheers
I also ditched mine to mate, my 10 row cooler is spot on, oil temps sit at around 80 - 100 Degrees C depending on driving moods.
I ditch the standard oil cooler and just shortened the pipe/tube from that to bolt the mocal sandwich plate to
Also if you want them i've got part numbers somewhere for proper blanking plugs to block off the coolant pipe the oil cooler feeds from
that would be good roly! that would be alot tidya cheers
matt i could of sworn you hadnt taken it off last time i saw it...or am i going mad?
HoocH
Engines turbos and gearboxes
Hi Hooch,
Been reading with interest.
We are having a lot of interest in our kits to fit on the Ibiza. I know we have spoken briefly, but this is something we will be happy to help with. 01908 821216.
Regards
Mark
Backdraft Motorsport.
HoocH
Sorry Hooch, my standard oil cooler is still there, just no plumbed into the coolant lines.
i thought so :D
ive got a really bad memory apart from really useless things, like, you still having your cooler fitted :)
right, had a constructive weekend.
i ditched the oil to water cooler plate. done what you guys said and shortened the standard tube.
and i stripped the head. couple of pics below
home made tool.
half way through
lots of bits and labels
head stripped
seats in (been in for a while now)
i also made an ecu cover
HoocH
Seats look cool, kind of evil from the back. My knowledge doesnt span to be able to have any input in you thread but it a good read. keep up the interesting work :)
cheers for the input guys.
this thread is abit boring at mo but it will be getting more interesting when things pick up in the next few weeks :)
HoocH
