H+R Front ARB Fitting Help
Nov 2, 2004
9,335
South Wales
Right, i've had this thing for about a year now, so it time to get it fitted. The only problem is the H+R bar is just that, a bar. So does the 25mm bar fit through the standard eye bolts on the legs?
Do i need different bushes?
I know Alex and Craig! has these fitted, any help lads?
Thanks.
Jan 8, 2007
2,958
Wiltshire
As per your old thread at http://www.seatcupra.net/forums/showthread.php?t=151811 Phil, I always thought you had to try and force the 25mm bar through the standard 22mm bushes - one of the main reasons I went Neuspeed:
IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
There should have been a pack containing the front and rear bushes with all the brackets and clamps needed for the rear bar. Call Motorsport Tuning on 01375 362828.
Nov 2, 2004
9,335
South Wales
I had everything with the rear ARB, thats been fitted for a while now. Everything was with that bar.
The front doesnt come with anything, just replacement bushes for the middle of the bar, which i assume is for fitment on the subframe. Nothing i could see for the eye bolts for the end of the bar.
Nov 2, 2004
9,335
South Wales
Right i found 2 bushes, one looks like its for the eyebolt, and one looks like it sits ine the middle of the bar as its split.
Great, 2 bushes short so far.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
01322 629880 is who you need to call Phil
(they are not always very helpfull tho in my experience) - hopefully you catch em on a good day
Backdraft
I have got the H+R bushes before for Hooch. If you dont have any luck then either give me a shout or call MSTuning on 01327 362828.
